IP Communicator on a Macintosh?
Is there a way to use IP Communicator on a MAC other than using a dual-boot type utility?
Re: IP Communicator on a Macintosh?
SJ Labs makes a softphone that will run on a Mac.
http://www.sjlabs.com/
Hope this helps. If so, please rate the post.
Brandon
Thanks Brandon,
I need to find out if a MAC version of IP Communicator is on the roadmap. I'll ask my Cisco AM.
The roundabout way. Install VMWare for MAC, install XP inside VMWare, Install IPComm on XP.
132
