IP Communicator on VMWare
Hi Guys,
Need help. I installed IP Communicator on a VMWare and the VMWare is running on MAC OS. I was succesfully installing the application and fine tune the audio well, but the problem is I can't configure the network preference of the communicator. It was greyed out, I can't set the TFTP server.
I'm thinking, it might be the binding of the LAN card to VMWare application.
Thank you.
Super Bronze
Re: IP Communicator on VMWare
It usually means you've logged in as a non-Administrator in the VM. It's restricted so users' can't break it.
Log in as local administrator and try again..
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
I was logged in as administrator, sounds odd but what I did was remove IPCom 7.4 and install the 7.3 and afterwards I can edit the network tab.
Thanks for the reply, I appreciate it.
Guest OS is Windows right?
You can add the TFTP IP via the registry
It's something similar to
HKCU > Cisco Systems > Communicator > TFTP Server 1
The trick is you need to add the IP in Hexadecimal.
Google 'convert IP to hex' for an example
1179
