Community Member
IP communicator over microsoft VPN with ISA server
LAN is 192.168.1.0 /24 if I use the uc520 (192.168.1.250) as my gateway, softphone IP communicator works perfectly. The problem is when used over an MS VPN through an ISA server. VPN tunnel works fine with access to all LAN however I am not able to reach the 10.1.1.1 tftp server. I tried to add a static route on laptop but still won't reach the 10.1.1.0 network.
139
