Community Member
IP Communicator over wireless not registering
Looking for others that may have run into this, IP Communicator 2.1.2.0 will not register when using wireless network but does on same machine over wired network.
Thanks in advance for the help.
Re: IP Communicator over wireless not registering
hardcode the device name under CIPC config and use that one to register it in CUCM
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
That is how we do our IP Communicators. We still have the problem not registering.
Community Member
I have a similar problem where it tries to start and says that it "Could not find a network adapter needed for registration" but like you it only happens when I am on wireless and not when wired. It has done this for the last several versions. The only way to get it working that I have found is to uninstall, reboot, and reinstall. This will get it working for a time or two but then it does it again later.
Community Member
I found the solution to my problem. I had to disable the VLAN Priority Support value under the advanced tab of the wireless card. After that the IP Communicator (v2.1.2) registered fine.
310
