Community Member
Ip Communicator Service Issue
I just finish installing CUCM v10.5 and I registered 2 Ip communicator client. They are register and I'm able to call from one to the other but the screen is stuck to "Select Service..." when I press Exit it bring me back to the same screen. It's kind of annoying, if anybody could help me with that it would be very appreciated.
I have attached an image with the screen I'm stuck on.
Thanks!
Thats because you havent
Thats because you havent subscribed to any service. Go to the phone in UCM, on the top right corner, there is a related links section, click the drop down and select subscriber/unsubscribe services.
Please rate useful posts.
Community Member
Hi George,I tried addind the
Hi George,
I tried addind the "Intercoms Call" service, since it was the only one available in the list, but I'm still stuck on the service screen.
DId you save/reset the phone
DId you save/reset the phone from CUCM after making the change?
Community Member
Yes I did. When I select the
Yes I did. When I select the Service Button on the IP Communicator it shows No Services Configured.
I have attached 2 images.
Try configuring Extension
Try configuring Extension mobility and see if that works. I am not sure about Intercom. Also, what services do you have turned on in CUCM?
Community Member
I have configured Extension
I have configured Extension mobility service but it didn't solve the problem.
Service Activated
-CallManager
-IP Voice Media Streaming App
-Extension Mobiltity
-TFTP
-SOAP - CDRonDemand
-AXL Web Service
What URL did you use for
What URL did you use for Extension mobility? Can you post the URL here? What happens if you post that URL into a web browser on your PC?
Community Member
http://192.168.0.18:8080
http://192.168.0.18:8080/emapp/ EMAppServlet?device=#DEVICENAME#
I get a " HTTP Status 404 - /emapp/%20EMAppServlet "
type: Status report
message: /emapp/%20EMAppServlet
description: The requested resource is not available.
There is space after /emapp/.
There is space after /emapp/. Is that how its configured in CUCM as well, please remove the space if it is.
Community Member
There was a space and I
There was a space and I removed it but my phone is stuck on requesting.
And when I put the url in the browser I get a blank page.
Community Member
Hi guys, Any luck with this
Hi guys,
Any luck with this problem? I also have it on 10.5 update 2
Community Member
Hi Jaiel On CUCM, under
Hi Jaiel
On CUCM, under Enterprise Parameters Configuration, have you changed your Secure/Phone url parameters to reference to your call managers IP address?
Tshepo
Community Member
The problem is due to the
The problem is due to the "idle timer" in the phone configuration page which you will probably find it to be set to 1 second. Most probably you didn't set this, but it came from the newly introduced "Universal Device Template", which get applied on auto-registration and some other features. If you want to avoid this problem, modify the parameter on the template, under User Management > User/Phone Add > Universal Device Template.
Wafik
Community Member
That one did the trick. :)
Thank you Wafik
Community Member
Wonderfull!!! I could solve
Wonderfull!!! I could solve the problem.
The Universal Device Template in autoregistration information overrided the idle options.
1786
