IP communicator setup
I installed IP communicator 7.0.4 but Network configuration is disable in the preference.
It installed on windows 7
I need this to specify the tftp server.
thanks
Red
Re: IP communicator setup
Try log into Windows as local administrator.
Michael
http://htluo.blogspot.com
Hi guys,
I have the same problem on my side even with the administrator.
Did you find anything to fix that ?
thanks !
I got It !!!
dont run it as a member from the administrators, it will not work.
Instead run it as THE administrator, this will let you modify the config.
Please rate if it help
I deleted all ipcommunicator item in the regedit
Windows UAC, right-click the shortcut and "Run as administrator".
/M
565
