ip communicator to receive a call
All,
I have ip communicator installed on my pc. I can make outbound calls without any issues. However, I can not use it to pick inbound calls. Is there a way to do that?
Thanks.
Re: ip communicator to receive a call
You'll need to elaborate on exactly what do you mean by that.
Do you not get calls?
1-way audio?
You pickup and calls drop?
Also is this CUCM or CME?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks. I put the phone in the wrong partition.
151
