IP Communicator via Citrix Xenapp 6.5
Is IP communicator supported on Xenapp 6.5? I have it published and it seems to be working other than a few quirks. DIdn't know if there was any offical documentation regarding settings for this.
  • Cisco IP Communicator does not support Windows XP, Windows Vista, or Windows 7 Fast User Switching.
  • Cisco IP Communicator is not supported in VMWare, Citrix, Terminal Services, Remote Desktop or other thin client environments.
  • Cisco IP Communicator is supported only on Windows XP, Vista, Windows 7, and Windows 8 as shown in the following table. Cisco IP Communicator supports x86-based processors running a 32-bit OS; 64-bit OSs are supported on Windows 7 (WoW64) and Windows 8. This integration runs as a 32-bit application in 64-bit versions of Windows 7 and Windows 8. All other supported operating systems are 32-bit only.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cipc/8_5/english/release_notes/CIPC_Release_Notes_8_6_chapter_00.html#CIPC_RF_A5233D61_00
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jamie...Do you know of any customers using IP Communicator in Citrix? Most applications are not supported in Citrix, but that doesn't mean they won't work!
Only issue I'm having now is it closes the first time its launched. After that, you can open and it works fine.
1298
