IP Communicator Vista
Does anyone know if there is a version of the IP communicator that works with Vista? I found a VPN client for Vista but cannot located an IP communicator. Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: IP Communicator Vista
IPC 2.1 supports Vista, you ca download it here:
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-comm
HTH,
Chris
HTH,
Chris
Thanks for your help. Worked like a charm
It does help, tremendously. For those that will install, don't forget to add the executable to your local or domain windows vista firewall policy. If that executable is not added, the soft phone will have limited capabilities. One way to tell you are 'limited' is that the time will be in GMT. Other things, such as services will not work either.
Bronze
117
