IP Communicator vs. IPCC Express
I have a user who has IP Communicator on their PC. When they call into the IPCC Express Queue the call hits the opening gretting and then goes to a fast busy. I also have IP Communicator loaded on my pc and hav no problem calling into the queue. Any suggestions greatly appreciated. In the past if I uninstalled and reinstalled IP Communicator that solved the problem. This time when I tried that the problem remained.
  • IP Telephony
Red
Re: IP Communicator vs. IPCC Express
Go to IP Communicator > Preferences > Network. Uncheck "Optimize for low bandwidth".
When you have that checked, CIPC would be in G.729 codec. I guess your IPCCX was installed as G.711. Without a hardware transcoder, the call would drop.
Michael
http://htluo.blogspot.com
I do not have the option under Network for Optimize for low bandwidth.
Using IPC 7.0.1.0
VIP Super Bronze
Two things:
1) Check to make sure both phones are configured identically, especially the device and line CSS.
2) What do you mean by "opening greeting"? You should either get audio from the script or not. If it starts playing audio then there isn't a codec problem (assuming the script and prompt files are done right). Is Unity in the call path?
Please remember to rate helpful responses and identify helpful or
143
