Community Member
IP Communicator with Cisco Call Manager Express
Is possible to use Ip comuniactor with CME? If so, can any one provide the configuration steps please.
Hall of Fame Super Red
Re: IP Communicator with Cisco Call Manager Express
Hi Sudheer,
Support for IP Communicator was added in CME 4.0 Have a look at the steps below;
SCCP: Configuring Cisco IP Communicator Support
To enable support for Cisco IP Communicator, perform the following steps.
Prerequisites
Cisco Unified CME 4.0 or a later version
Cisco IP Communicator 2.0 or a later version
IP address of the Cisco Unified CME TFTP server
(Optional) Headsets with microphones for users
DETAILED STEPS
Step 1 Download the latest version of the Cisco IP Communicator software and install it on your PC.
The download website is at http://www.cisco.com/pcgi-bin/tablebuild.pl/ip-iostsp.
Step 2 (Optional) Attach a headset with microphone to your PC.
Step 3 Start the Cisco IP Communicator application.
Step 4 Define the IP address of the Cisco Unified CME TFTP server.
a. Open the Network > User Preferences window.
b. Enter the IP address of the Cisco Unified CME TFTP server.
Step 5 Wait for the Cisco IP Communicator application to connect to Cisco Unified CME and register.
Step 6 Configure the extension numbers and line buttons for the Cisco IP Communicator.
Use the normal phone provisioning commands described in the "SCCP: Creating Directory Numbers" section. In the type command, use the CIPC keyword to identify this phone as a Cisco IP Communicator.
SCCP: Verifying Cisco IP Communicator Support
Step 1 Use the show running-config command to display ephone-dn and ephone information associated with this phone.
Step 2 After Cisco IP Communicator registers with Cisco Unified CME, it displays the phone extensions and soft keys in its configuration. Verify that these are correct.
Step 3 Make a local call from the phone and have someone call you. Verify that you have a two-way voice path.
SCCP: Troubleshooting Cisco IP Communicator Support
Step 1 Use the debug ephone detail command to diagnose problems with calls. For more information, see the Cisco Unified CME Command Reference.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807e13a7.html#wp1046762
Hope this helps!
Rob
Community Member
Rob THANKS AGAIN !!! Enrique
Enrique Villasana
Community Member
Thanks Rob
I am able to configure the IP communicator and it is registering with CME. I have another question.. how can i configure IP communicator to use my desk phone number instead of giving a new number.
6811
