05-12-2009 12:13 AM - edited 03-15-2019 05:57 PM
I have problems running Cisco IP Communicator (CIPC) on Windows Vista operating system. Is the CIPC compatible with vista? Please help.
Solved! Go to Solution.
05-12-2009 05:36 AM
7.0(2), you can easily find this information looking at the download center or searching IP Communicator on CCO
java
if this helps, please rate
05-12-2009 01:47 AM
CIPC working with Vista, make sure you use lastest software.
05-12-2009 03:12 AM
Thanks a lot for your response. Please what is the latest software version for CIPC?
05-12-2009 05:36 AM
java
