IP Communicator x Qos
I want to match all traffic from IP Communicator to CUM and others IP's device (signaling and conversation) to implement QoS Policies.
Do you have the standart port(s) and protocols to do that with an ACL?
Does anyone have a document explain that?
Tks a lot
Tasso
Re: IP Communicator x Qos
It pretty much follows the same as an ip phone:
· TFTP (UDP 69)In order to obtain phone configuration and software
· SCCP (TCP 2000)For skinny (SCCP) signaling
· HTTP (TCP 80)In order to access IP Phone services
· RTP (UDP 16384-32768)For audio
Also a link to a good guide:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/fqos_c.html
Tasso,
Take a look at the Campus QoS Design section of the QoS SRND below. Drill down to the specific hardware model. There is an example config for Softphone trafic.
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
Hope this helps. If so, please rate the post.
Brandon
Tks!
I'm configuring into to two routers.. I need some information about Layer3/4 infos to match the traffic.
Tks a lot
Tasso
134
