ip communicator
Hi at all,
i need to change the background image on my ip comminicator.
It's possible?
Can I've  a help to do this?
Thanks in advance
giancarlo
1 REPLY
ip communicator
Yes, just search CSC for the instructions on how to change the background on a 7970 and it's the same procedure and image size.
There are plenty of threads with the instructions and image size.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
199
