IP Communicator
I have IP communicator installed on my laptop. Works fine over wired connection. Should this be able to work over my 802.1x wireless connection? (Currently it won't)
Bronze
Re: IP Communicator
Are you use your wired MAC address on CCM??
If yes.. please put your wireless MAC on CCM instead. This way.. it will work when you are on wired or wireless network.
Ken
Re: IP Communicator
Yes, it works great. On the network settings under preferences, look under the "Device Name" section. Highlight the device name to which Communicator registers with the CCM. Paste that device name in the section "Use this Device Name". Whenever you boot up Communicator, it will register with that device name regardless the network connection you use.
Re: IP Communicator
It will work fine, thats the setup I have on my laptop.
191
