Community Member
IP Communicator
Is there anybody that can help with support for this product ??
we would like to use it for our "home workers" but have some support issue's.
Scott.
Green
Re: IP Communicator
Yo may want to check Cisco Partner's link or
http://tools.cisco.com/WWChannels/LOCATR/jsp/partner_locator.jsp
If you have some issues and have a valid Cisco Contract open a TAC Case.
Silver
Re: IP Communicator
Hi Scott,
It's a pretty simple product to use.
If you dont have the resources internally, would suggest smartnet contract with each licence.
Or are you having a specific problem getting it installed and going?
Cheers,
Tim.
Community Member
Re: IP Communicator
Hi Tim,
Its pretty specific..........We cannot get the "services" page to display, all we get is what looks like a load of html code. Everything else is fine. We need the services page for extension mobility purposes.
Oh and its only the Win XP Pro machines that have this problem , the others run dinosaur Win2K and they are fine.
Scott.
Community Member
Re: IP Communicator
Are you running a VPN client on all the boxes? I had an issue with a Checkpoint VPN client causing the same issue on the services page. I had to disable the VPN security policy, launch IPC, then re-enable the security policy. Once IPC had the file it needed, it was good to go, Services button and all.
283
