Ip Communicator
How do we get a MAC address for an Ip Communicator?
Re: Ip Communicator
I usually use the MAC of the PC in where the IP Communicator is used, but also you can use a TAPI for emulate a MAC Address of a IP phone
Re: Ip Communicator
Hi Kartik,
Do you need info on how to get the MAC ID for a CIPC from a PC? or something else, Pls confirm
Ip Communicator
Hi Karthik,
If you want to user CIPC from your Laptop or from your Computer. First the MAC address of that either should be configured in Call manager.
To get the MAC address from your computer.  Start --> Run --> then type cmd it will open the below window
Then execute "getmac" which will retrive your MAC address of your local machine....
Note :- If it is laptop you may get 1. LAN MAC, 2. Wireless MAC, 3. VPN MAC as well
Kulasekara Raja. K
Hall of Fame Super Gold
Ip Communicator
Five years aged posts, unlikely the OP still needs an answer.
274
