Ip Communicator
What are the ports that the Cisco IP Communication use? I need the number of the ports to open these ports in the firewall.
thanks
  • IP Telephony
Re: Ip Communicator
Im am not shure if you meed the soft phone og det IP Coomunication ?
IP Communication
Depending on SIP or Skinny(SCCP).
If it is a normal CCM and skinny setup here is thoe ports.
SCCP port 2000 to 2002
RTP range from port 16383 to 32767
This is for SCCP , if you need gatway comminication also there is more ports.
/Soren
Hall of Fame Super Red
Re: Ip Communicator
Hi Ricardo,
Just a little added info to the great tips from Soren,
This link shows the TCP and UDP Ports used on the various CCM Versions;
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/sec_vir/udp_tcp/index.htm
Hope this helps!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
131
