IP Comunicator problem on CCM 4.1.3
nenad_2007
what is the news't version which I can use with CallMnager 4.1.3? When I install CIPC greater then version 1.1.5.0 I have problem my IP Communicator continously reseting.
Rob Huffman
Hi Nenad,
Have a look at the System requirements in these release notes. It could be a CCM or PC restriction you are hitting;
These releases are supported with Cisco IP Communicator Release 2.1(1):
Cisco Unified Communications Manager Release 6.0 (SCCP and SIP)
Cisco Unified Communications Manager Release 5.1 (SCCP and SIP)
Cisco Unified Communications Manager Release 5.0(4) (SCCP and SIP)
Cisco Unified Communications Manager Release 4.2(3) SR1 (SCCP)
Cisco Unified Communications Manager Release 4.1(3) SR4 (SCCP)
This Cisco Unified Communications Manager release is now the minimum release with or without Cisco Unified Video Advantage integration.
From this doc;
Release Notes for Cisco IP Communicator Release 2.1
http://www.cisco.com/en/US/products/sw/voicesw/ps5475/prod_release_note09186a0080758002.html#wp40874
Release Notes for Cisco IP Communicator Release 2.0
http://www.cisco.com/en/US/products/sw/voicesw/ps5475/prod_release_note09186a008073235c.html#wp2431921
Hope this helps!
Rob
Thank's I will try
