Community Member
IP COMUNICATORS NOISE USING PLANTRONICS USB
I?m using headset plantronics 400(dsp) usb and ip comunicator 2.0.1.1 and when a calling to ip phone (hard phone) or analog or whatever, in the ip comunicator hear fine but the hard phone hears noise (like electrical noise) after the ip comunincator stop talking.
any ideas?
thanks
Community Member
Re: IP COMUNICATORS NOISE USING PLANTRONICS USB
This issue is documented in Cisco bug ID CSCdy33907 and resolved in SoftPhone Interim build 1.3(2.4) and later.
This problem has been noted only when the call is made with the G.729 codec. A workaround to this problem is to use G.711.
Hall of Fame Super Gold
CSCdy33907 does not appear to apply to the problem described.
Poster is using IP communicator 2.0, not softphone 1.3
He did not mentioned of being using G.729
CSCdy33907 is not even visible in Bug toolkit.
Community Member
Thanks for helping I made a test with another dsp 400 that was acquired 1 year ago and the noise doesn?t exist in this one so I think that the news dsps 400 are failing so, We must replace them.
113
