IP Conference Phone 8831
Hii,
I want to buy a Conference kit for the meetings rooms and I need some opinion about the models, in the past I used 7937 and now I want to by 8831 and I
want to know your ideas about this conference kit ( is k or not, how many license....  ).
I use CallM 8.6 + Gateway 2921
Th
In terms of licensing, there's no difference between the 7937 & 8831.
In terms of cost, the 8831 is cheaper.
In terms of avavilability, the 7937 is easier to get hold of compared to the 8831 right now. (That should be improving...)
Both will work with CUCM 8.6 - although you may need the latest device pack to be installed, depending on your exact CUCM version, to support the 8831.
(Just for reference, Cisco announced last week that the 7937 goes end of sale March 2014.)
GTG
Please rate all helpful posts.
VIP Purple
Hi Gabriel,
You can also refer the discussion for license details:
https://supportforums.cisco.com/message/3954164#3954164
a. 7937 supports G.711 ,G.729 and G.722 codecs while 8831 supports iLBC as well .
b. 7937 does not support Daisy Chaining while 8831 does that.
c. 7937 does not support Wireless Microphones while 8831 does that.
d. 7937 works on SCCP and 8831 works on SIP.
e. 7937 does not support encryption while 8831 supports encryption.
regds,
aman
VIP Purple
Hi Gabriel,
You can also download the pdf of IP Phone portfolio and check under 8800.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/prod_brochure0900aecd800f6d4a.pdf
regds,
aman
Hall of Fame Super Silver
Keep in mind that 7937 has been announced end of sale and end of life, so 8831 is only viable option as even though you can still order 7937, why would you buy more expansive phone that is being killed.
HTH,
Chris
Thanks for help guys.
VIP Purple
Hi Gabriel,
thanks for rating.
regds,
aman
1743
