Community Member
IP Handset Question
We will very soon be upgrading from CCM 4.1.3 to version 5.1.1.b
We will also be changing IP Handset signalling from SCCP to SIP.
My question is:-
We are currently using 4940G and 7960G Handsets but we need to implment various security standards such as:-
1) Media and Signalling Encrytpion
2) Utilisation of 802.1x
3) Security signing of Firmware software on phones.
4) Utilisation of 802.3af power delivery via POWERDSINE manufactured 24-Port PoE Midspan AC Input w/Managenent Switch rather than Cisco PoE Switches.
Would the present 7940G and 7960G handsets suffice in this model?
I have been advised to upgrade these handsets to the 7941G and 7961G model.
Please help.
1 REPLY
Silver
Re: IP Handset Question
UPGrade SIP:
Step 1 Obtain the default configuration file as follows:
a. Go to the Cisco.com SIP IP 7940/7960 phone software-download site at http://www.cisco.com/pcgi-bin/tablebuild.pl/sip-ip-phone7960.
b. Download the SIPDefault.cnf file to the root directory of your TFTP server or to a subdirectory in which all phone-specific configuration files are stored.
Step 2 Using an ASCII text editor such as vi, open the file.
Step 3 Modify the following required parameters:
line1_name?Number or e-mail address for use when registering. Enter a number without dashes. For example, enter 555-0100 as 5550100. Enter an e-mail ID without the host name.
proxy1_address?IP address of the SIP proxy server that is used by the phones. Enter the address in IP dotted-decimal notation or use the FQDN.
proxy1_port?Port number of the SIP proxy server that is used by line 1.
Step 4 Modify additional parameters as needed.
Step 5 Save the file to the root directory of your TFTP server or to a subdirectory in which all phone-specific configuration files are stored.
This URL should help you:
http://www.cisco.com/en/US/products/sw/voicesw/ps2156/products_administration_guide_chapter09186a008073f4aa.html
132
