IP Phone 6921 support on CUCM 6.1 ???
Dear All
My friend ( Who is a voice administrator of a company ) bought IP Phones model 6921 . He is running a CUCM version 6.1 where he found later that, the 6921 is not support on CUCM 6.1 version and the support starts from CUCM version 7.1 and later . Is there any workaround exsist other than an upgrade to the CUCM . Is there any supportive files or patches available at cisco to make 6921 work with CUCM 6.1 .??
All your inputs are highly appreciated
Thanks and Best Regards
Rajesh
1 ACCEPTED SOLUTION
Re: IP Phone 6921 support on CUCM 6.1 ???
Hi Rajesh,
Its true, the 69XX series is supported on CCM 7.1.2 or later only.
Find the data sheet which provides complete information:
http://www.ciscostadium.org/en/US/prod/collateral/voicesw/ps6788/phones/ps10326/ps10343/data_sheet_c78-541534.html
Pratik
Hi Rajesh,
Pratik
Thanks very much for the response Mr. Patrick
I would like to know is there any workwrount to make it work  with teh current situation ?
or
A call Manager upgrade is a must ??????
Hi Rajesh,
As mentioned in the document, its not supported in lower version (no patch) and you have to upgrade to min. 7.1.2.
Pratik
561
