IP phone 6921
Have 2 Cisco 6921 IP phones that display "Not Registered".
How do I get them to register?
  • IP Telephony
IP phone 6921
Start by mentioning system and version you're using
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: IP phone 6921
Lets pretend I don't know anything about the phone system. How do I find the system and version?
IP phone 6921
check out if one of the pair of ur cat6 cable broken/cut......u can use tdr test command
check whether registered with wrong mac address
check whether while adding in CUCM right model has been selected
check whether PoE switch is providing right power on its port....as its a class 2 device
check whether proper partition css et has been selectd or nit.......
please rate if found helpful
VIP Purple
IP phone 6921
Hi John,
As Mr Jaime has aid, You need to know the CUCM version .Along with that whether Auto-registration is enabled or u need to manually enter the MAC -address of phone.
In some cases, u also need to enter the Device Pack for phones to register.
regds,
aman
104
