IP phone 6941 not loading the firmware
we have issues with the 6941 IP phones which we have recently started deploying, these phone will be loading the firmware from CUCM 8.0.3 but they are stuck in some stage and displaying only the Cisco log message on screen. These phones were previously receiving the IP confiuration from DHCP and we can check trough CDP on swtiches as if they are connected. But sicne their loading of the firmware is failed for some reason they are not even showing as CDP neighbours on switches and also no IP addresse are leased from DHCP pool. we have unplugg the phone, out them back and shut/no shut the switch port but phone gets the power from swtich and displays cisco logo message but not getting IP addresses from DHCP and also not showing up as CDP neighbours. Please anyone help in identifying the issue?
Tasneem
VIP Purple
what is the firmware version u are uploading for 6941 IP phones?
regds,
aman
it looks like swtich is not learning the MAC addreses for these phones, previously it was but not any more.
Can you try connecting the 6941 to a switchport where another phone is working fine. Has a factory reset been tried on any 6941 yet?
Manish
VIP Purple
Hi ,
this means it was working earlier.
any change done on call manager.
regds,
aman
Hi Amanso,
We tested 7940 phone they work fine but right now the problem i am working why they are not showing in CDP neigbours and why their MAC address are not being learned on swtich port. There is not switch port security deployed on switches anywhere
VIP Purple
Hi ,
what does the switch port show ?
I was just seeing the bug
6921 not sending immediate CDP upon PC disconnect
CSCtj92865
Symptom:
6941 6921 6961 when plugging a different PC the switch port goes into err-disable state with the error "new MAC address is seen".
Conditions:
Using dot1x
Workaround:
wait for some time before plugging the new PC. The phone needs to send CDP to indicate that the pc port is disconnected so it can log off the session.
Known Affected Releases:
(1)
9.0(3)
regds,
aman
141
