IP phone 7821 FAC is displayed on screen (not masking with *)
Hi All,
On our 7821 phones, When we enter the FAC after dialing a number it shows FAC on the screen without the * to mask it. In every other model of phones we have the normal behaviour is to mask the FAC with * after dialing the phone number.
We are using -
CUCM version: 8.5.1.12900-7
Device Pack version: 8.5.1.17126-1
7821 Firmware version: 10-1-1SR2-1
I would be thankful if someone can help me on this issue.
Hi Thivanka,
Yes.
It is just a minor upgrade.
Before u proceed for upgrade, check compatibility marix
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
regds,
aman
Aman Soi
This could be a bug.
CSCuc53263
FAC Codes are not being masked for SIP 8961/9971 phones.
regds,
aman
Thanks for your feedback.
So there is no option other than an upgrade to CUCM version 8.6.x. Isn't it??
Thivanka
Hi Thivanka,
Yes.
regds,
aman
Thanks Aman,
Will check compatibility and proceed for the upgrade.
Thivanka
