04-25-2014 02:02 PM - edited 03-16-2019 10:35 PM
Hello engineers!
I have fifteen ip phones 7821 model but I only could register 5 of them, the rest give me the "unknown" message. I have understood that this phones need UCL basic license.
My question is, that if I have some enhanced UCL licenses available, could this phones take this enhanced licenses in order to registering in the CUCM?
I have 9.1.2 CUCM version.
Actually, I have the next licensing:
Thanks for your help!
Regards!
Iván
05-07-2014 04:13 AM
Yes they are working perfect now. Have you faced the same problem ?
05-07-2014 04:55 AM
I did not face the same problem.
thanks for sharing the info.
regds,
aman
05-07-2014 09:21 PM
My CUCM is version 10.x and this issues is still not resolve.
refer to BugID "CSCun03177"
For version 9.x is resolved. but not yet for version 10.x
you need to request TAC and they will send you "Temporary License" for you depend on how many 7821 IP Phone you bought.
for version 10.x is waiting for new "Device pack" version "10.0(1.11005.1)" to solve.
05-14-2014 09:12 PM
Hello you all!
My issue has been resolved with TAC help, it turns out that it was not a license issue, I hit the next bug:
CSCun23612
7841 Cannot join VLAN if broadcast over 30kbps.
https://tools.cisco.com/bugsearch/bug/CSCun23612
Its weird because I have the 9.1.2 CUCM version, and it says that only 10.1.1 is affected, but we did the workaround and it worked.
Right now, I am only check if all the phones are registered.
Thank you to all of you for the help.
Regards!
Iván
05-14-2014 11:42 PM
HI Ivan,
thanks for sharing the bug[+5]
can u please let us know how TAC engr. found this issue since your issue was related to available Licenses being not consumed ? any findings ,let us know.
regds,
aman
05-15-2014 12:43 AM
Sure Aman,
Reviewing the CDP process, the engineer realized that phones that were not registered did not get IP address and did not respond to ping messages, even if they were configured with static addresses. With these symptoms he found this bug in his database.
10.1.1SR1 is the firmware that contains the fix for this bug.
Thank you again.
05-15-2014 01:10 AM
thanks...
Basically,it was a registration issue.
regds,
aman
