Community Member
IP Phone 7906
How to put a static IP address on my IP Phone 7906 and how to change the dhcp address?
1 ACCEPTED SOLUTION
Bronze
Re: IP Phone 7906
Hi, this option by default is locked, press **# to unlock this option and you will be able to set the appropiate value.
Hope this help
David
Bronze
Re: IP Phone 7906
Hi, to put a static IP Address: Settings->Network Configuration->DHCP enabled=NO and you can configure a static IP, SubnetMask, TFTP IP Address....
Choose Yes if you want to use DHCP to automatically configure the network settings on your server.
Hope this help
David
Community Member
Re: IP Phone 7906
DHCP enabled = Yes there are no possibility to modify, I can choose only "exit" function, there are no option to choose "select"
Bronze
Re: IP Phone 7906
Hope this help
David
560
