IP phone 7911 not coming after a factory reset
Hi All,
I have an serious issue here, Cisco 7911 IP phone is not coming up after I performed a factory reset. I have SCCP11.8-5-2S load available in the CUCM TFTP 8.5.1 and this load is working fine with all other phones in my cluster. When I tried performing FR, the phone screen shows upgrade as attached in the picuture but never completes.
My observation: I went to connected switch and put the command show cdp entry SEP0022905C2DD7, it showed the phone has no IP got and the load file.
Device ID: SEP0022905C2DD7
Entry address(es):
Platform: Cisco IP Phone 7911,  Capabilities: Host Phone
Interface: FastEthernet1/0/48,  Port ID (outgoing port): Port 1
Hold time : 127 sec
Version :
79XX_default_load
advertisement version: 2
Duplex: full
Power drawn: 5.000 Watts
Power request id: 11735, Power management id: 3
Power request levels are:5000 0 0 0 0
Management address(es):
Kindly let me know how to make phone back to normal working condition? Your help is much required and appreciated.
Lajith P
2 ACCEPTED SOLUTIONS
You could try Wiresharking
You could try Wiresharking the phone to see what's going on. With firmware update problems, it's often the only way to diagnose what's really going on. GTG
Please rate all helpful posts.
Silver
For this upgrade to
For this upgrade to successfully pass on you have to implement correct DHCP, TFTP environment so that phone can upgrade itself as it should...one other way is that you upgrade it with your local PC using this method:
http://draganchilly.blogspot.com/2014/02/cisco-ip-phone-recovery-procedure.html
After that you should just connect phone to network and it will work like others...
HTH,
Dragan
HTH, Dragan
That almost looks like the
That almost looks like the phone isn't getting an IP address. GTG
Yes. But an another new 7911
Yes. But an another new 7911 phone gets IP address and works good when connected to the same port.
Looks like the issue is specific to that phone.
Please advise further.
Silver
For this upgrade to
HTH,
Dragan
HTH, Dragan
1245
