Ip phone 7911G and Class of restriction
Hi guys,
I have CISCO Unified Communications express 7.1.0.0 and this configuration on my router:
dial-peer voice 10 pots
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 7
destination-pattern [0,1,3-9]T
progress_ind alert enable 8
port 0/0/0
dial-peer voice 11 pots
port 0/0/1
dial-peer voice 12 pots
port 0/1/0
dial-peer voice 13 pots
port 0/1/1
dial-peer voice 50 pots
translation-profile incoming INCOMING_CALLER_ID_TRANSLATION
incoming called-number .%
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 51 pots
direct-inward-dial
port 0/0/1
forward-digits all
dial-peer voice 52 pots
direct-inward-dial
port 0/1/0
dial-peer voice 53 pots
direct-inward-dial
port 0/1/1
forward-digits all
I want to implement Class of Restrictions for only one e-phone in outgoing. Now I have the inside numbers that begin all with the number 2  They are: 2110, 2210,2211, 2212 etc...
I want that the ephone 22 can effect only in exit the inside numbers that begin with the number 2 and in entry to receive the inside phone calls, national, international. All the others ephones  must be able to make and to receive all the phone calls, to any destination. Which is the configuration to make in the router? Thanks for your support. Regards
205
