Community Member
Ip Phone 7925 & CCM 4.1
Is it possible to use 7925 with CCM 4.1. Because there is no 7925 when we try to add a new device.
1 ACCEPTED SOLUTION
Re: Ip Phone 7925 & CCM 4.1
You need to install the latest devicepacks to add support for new models
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
150
