06-07-2010 05:54 PM - last edited on 03-25-2019 07:59 PM by ciscomoderator
Configuring a new 2801 ISR running Version 12.4(15)T10 IOS & Version 4.1(0) CME.
I'm trying to add a 7925 Wireless IP Phone. I downloaded the CP7925G-1.3.4SR1.tar which is supposed to be the latest 'Skinny Client Control Protocol (SCCP) Software' and according to the " ... Release Notes with the Cisco Unified Wireless IP Phone running with Cisco Unified Communications Manager 6.0 and later, and Cisco Unified CallManager 5.1, 4.3, 4.2, and 4.1. "
When I import the files using 'archive tar /xtract tftp://172.16.1.11/CP7925G-1.3.4SR1.tar flash:' The files import to a folder flash:/P7925G-1.3.4SR1. but I can't get the system to recognize them.
I deleted them and repeated the import using CCP 2.2. Again the files imported to the folder but still they are not recognized.
Help!
06-07-2010 06:10 PM
It does not appear that the 7925 is compatible with CME 4.1. First compatibility matrix that shows the 7925 is for CME 4.3:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme43spc.htm
HTH.
Bill
06-07-2010 06:33 PM
Will,
You are completely rigth, he needs al least CME 4.3 to use the 7925 wireless IP phone.
Please rate this post if was helpful
Walter Solano
Cisco UCCX Specialist
06-07-2010 06:36 PM
Bill is right on the spot, read the doc:
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
