IP phone 7937G
How to add a 7937G ip phone to the call manager version 6.0.1.2000-3. It is not on the list when I go to Device - Phone - Add new - Phone type
Thanks.
1 ACCEPTED SOLUTION
Re: IP phone 7937G
Read once again my post, i said "device pack" NOT "service pack". They're not the same thing and shouldn't be confused.
CSCsq39150            Bug Details
Cannot find polycom 7937 phones in CUCM phone create menu
Symptom:
polycom 7937 phone not showing in phone create  menu
Conditions:
CUCM 6.0 or earlier
Workaround:
Install latest dev pack : phone was added in following packages
4-1-DevPack-59
4-2-3DevPack-36
4-3-1-DevPack-16
5-1-2-3111-1
5.1.3.2104-1
6-0-1-2111-1
There is no other way, if you want to use the 7937 you NEED to install the devpack, which requires a cluster reboot as it will add support for new models.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: IP phone 7937G
Install the latest device pack for your CUCM version and then look in the list again
java
java
Re: IP phone 7937G
Thank you for the answer.
Installing a service pack may or may not have implications to other systems, like Unity or UCCX. I am looking for a different solution, if there is one available.
Re: IP phone 7937G
Symptom:
Conditions:
CUCM 6.0 or earlier
Workaround:
4-1-DevPack-59
4-2-3DevPack-36
4-3-1-DevPack-16
5-1-2-3111-1
5.1.3.2104-1
6-0-1-2111-1
java
java
Re: IP phone 7937G
Thank you.
439
