IP Phone 7940
The problem i have with the 7940 phone is that they keep showing the message Configuring IP randomly. To overcome this i usually unplug the phone from the network and then plug it back in and after that it works fine without any issue but this is not a proper solution so any one can help in this manner. I have CCM 4.2 and the DHCP for the phones are created on the Router.
1 REPLY
Green
Re: IP Phone 7940
Make sure you are using latest phone load
Is phone resetting?
check EVent Viewer
Thats the topology
I would open a TAC case for more investigation
108
