IP Phone 7940G Stuck in TFTP Timeout
Hello all
I have 2 Cisco IP Phones that boot up and stay stuck on TFTP Timeout. I know the tftp server is working be cause i was able to obtain an IOS to a router from it.
I am trying to manually configure these phones for SIP but can't even press the setting button to enable. Any help would be much appreciated.
D.
Message was edited by: dmendezckpt
Re: IP Phone 7940G Stuck in TFTP Timeout
7940 SIP loads are somewhat out of scope for SBCS deployments. If you have CUCM server handy, instructions for conversion is below. If this does not work please kindly open a TAC case.
Rgds,
Tomoo
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
You could also try and use IOS as the TFTP sever. In any case, make sure that the tftp server has the following files.
OS79XX.TXT
P003.sbn
P003.bin
P0a3.loads
P0a3.sb2
Use the link that Tomoo suggested to figure out the content of these files. You may need assistance from TAC for converting it to the SIP firmware.
-Saurabh
11236
