09-23-2010 07:05 AM - edited 03-16-2019 12:58 AM
Dear All
I am facing a strange issue with Two different Customers Now and I wonder if anybody face a smilar issue
The issue is that an IP phone 7941/61 G being restart ( and if there is a call being disconnected) when a PC that is connected to it is being Disconnected or Restarted .
- I tried ( with the help of Cisco TAC ) to change the FW of the IP phone to different Versions ( from oldest 8.3.2 ) to the newest (9.0.2) ( note : the current is 8.5.3 ) .still the issue repeated .
- I Collected the traces and issue seems to be the "UpdateCapability" meesge is huge ( more than 1800Bytes Data ) and being fragmented and somehow it is not reachin the CUCM . Cisco Said somthing in the network. But the network have been checked for possible fragmenting points and nothing appeares
- Also I have another customer with other different network setting and the issue is exactly the same
The site that host the phones is a Remote site , and the CUCM is in the HQ. CUCM version is 7.1.3
Note: I had the same issue in another Remote Site ( with the same phone model ) but this one was registered on a a CUCM 4.2.3 windows based and the issue being resolved by upgrading the Firmware to 9.0.2 However this version still not working my case
Has anybody faced that issue before ? any guideness or other point of view to look at this issue
thanks
09-23-2010 12:33 PM
Try
If MSS on CCM server is set higher than the MTU is causes the phone to crash. You might be hitting http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk85434 .
10-01-2010 07:01 AM
HI ,Thanks for your answer
I tried upgrading the Phone to 9-0-3 and didn't solve the problem as well , problem still presist
any suggestion
