IP Phone 7941 NOT displaying a Time Zone?
Hello All,
CallManager: 8.0.3.22026-1
IP Phone: CP-7941G
I was configuring a phone for a user that is located in a separate location then our main location, which is where I am. We have Device Pools configured for ALL of our locations with corresponding Time Zones. So I configured to phone for the remote location's Device Pool as well as all the other information required. But when I look at the LCD screen of the device it is showing 8:47 pm, when it should be showing 1:47 pm (*PST). Going to the phone's IP Address in a browser I can see that the Time Zone field which SHOULD say, "America/Los_Angeles", is just blank.
But if I look at the same info for ALL the other phones that are currently in that location, they are all displaying the correct time and the correct Time Zone. So I'm not sure why this phone I'm configuring is showing the wrong time/time zone?
I thought maybe it was because of the gateway the phone is connected to, so I switched the Device Pool to the Pool where I currently am, which should have changed the Time Zone to "EST". But after resetting the phone it is still displaying the incorrect time as well as NO Time Zone at all...
Anybody have any idea why this could be happening? Any thoughts or suggestions would be much appreciated!
Thanks in Advance,
Matt
UPDATE:
Just remembered a while back we had to erase the ITL file on all the phones because of a certificate issue so it could then download the correct ITL file.
So I just realized that this phone I'm configuring has not been turned on in quite a while, so I just erased the ITL file and the phone is rebooting now and currently it's updating the firmware. I'll post back if this has fixed the issue once it is complete, but I'm assuming it will...
Matt
1 ACCEPTED SOLUTION
If you have device mobility
If you have device mobility configured, the device pool will follow the subnet the phone is in.
Please rate useful posts.
Ok, so the phone just
Ok, so the phone just finished upgrading the firmware and now it is displaying the Time Zone of the zone I am currently physically located in and NOT the Time Zone of the configured Device Pool.
So is this expected behavior, since the phone is not currently PHYSICALLY located at that location?
Thanks Again,
Matt
Hey George, thanks for the
Hey George, thanks for the reply!
Yes, you are absolutely correct. If I set Device Mobility Mode from Default to Off, the phone re-registers and the correct time for that time zone is displayed...!
Awesome, thanks again George. Much appreciated!
Thanks Again,
Matt
540
