IP phone 7942
Have a Cisco IP phone that continues to display "Configuring IP"
What do I need to do?
IP phone 7942
Do you have DHCP configured??
Or have tried manual IP config???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: IP phone 7942
IPv4 is DHCP enabled, IP address is shown
IPv6 is DHCPv6 enabled, IPv6 address is blank
VIP Purple
Re: IP phone 7942
Hi John,
You need to check the following:
a. reachability of Call Manager servers from phones.
b. whether Auto registration is enabled else u need to manually enter the MAC address of 7942 .
c. what is the version of call manager u are using ?
d. If it is DHCP enabled, have u defined TFTP IP address of CUCM server on which TFTP service is running  in pool.
regds,
aman
Hall of Fame Super Gold
IP phone 7942
Your phone could be in the wrong VLAN (no voice VLAN enabled).
Your voice VLAN may not have any DHCP configured.
IP phone 7942
Do you use a Cisco call control platform? If not, this is not really the right forum.
210
