07-01-2014 03:59 AM - edited 03-16-2019 11:16 PM
Hi All,
Appreciated if someone could help on the issue, as how to divert/forward the incoming call(external) from one extension 200 to another IP phone extension 202. The extension 200 physical phone is not present that y it is said unavailable and divert to voicemail.
Pls help....Many thx
07-01-2014 04:49 AM
If you are using CUCM then you can use translation pattern (under call routing) for it.
Suresh
07-01-2014 04:54 AM
Hi Kumar,
Thanks for replying. I'm using the CME would it be the same? Can you give me some confguration example? Many thanks
07-01-2014 06:26 AM
Then you need make translation rule & profile as below.
voice translation-rule 1
rule 1 /^200$/ /202/
voice translation-profile divert200
translate called 1
And put below command under voice port where from calls are coming on CME.
translation-profile incoming divert200
Suresh
