IP Phone 7945G
I have setup my IP phone with one default directory number. eg. 8456. I noticed that this number is setup at line 2.
How do i make sure that this directory number is setup at line 1 ?
I cannot find this settings in CUCM.
I m using CUCM 8.5.1.
The reason why I m asking is because I noticed that the default line 1 has more ringtone to configured while line 2 where my directory number is configured has only 7 ringtones.
I have users asking why can't they used line 1 instead.
1 REPLY
Re: IP Phone 7945G
First, you can rearrange the lines on a phone by going to the phone page in Device > Phone, and once you've selected your phone from the search results, choose the modify button at the top of the list of lines.
Second, the ringtone thing is a trouble spot for a lot of people. You have two options:
1) set the default ringtone for the phone to a fancy one, the set your line to use the default.
2) take a copy of the ringlist.xml file from TFTP and copy it to distinctiveringlist.xml. This will make both lists the same, but is more complex to setup and effects all phones.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
135
