Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ip phone 7961-g
How many lines can be terminated in this phone? Can al l of them can be used at the same time and how?
Hall of Fame Super Gold
Re: ip phone 7961-g
Are you using callmanager? that depends on the version of callmanager you're running.
Hall of Fame Super Red
Re: ip phone 7961-g
Hi Tarsem,
The 7961G is a 6 button phone that can have 6 Lines terminated. Using Hold/Resume Answer/End Call Softkeys you can use all 6 lines at the same time. You may need to tweak the default Phone Button Template to set all 6 buttons to be used for Lines.(Device > Device Settings > Phone Button
Template)Have a look;
Cisco Unified IP Phone 7961G
It provides six programmable backlit line/feature buttons and four interactive soft keys that guide a user through call features and functions, and audio controls for high-quality duplex speakerphone, handset, and headset. A built-in headset port and an integrated Ethernet switch are standard with the Cisco Unified IP Phone 7961G. The phone also features a best-of-class large, higher-resolution grayscale pixel-based LCD (Figure 2). The display provides features such as date and time, calling party name, calling party number, and digits dialed.
From this good Data Sheet;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet0900aecd802ff020.html
An optional 14-button add-on module, the Cisco Unified IP Phone 7914 Expansion Module (part number CP-7914=), provides 14 additional buttons for programming directory numbers or speed dials, or a combination of the two. Up to two expansion modules can be used with the Cisco Unified IP Phone 7961G.
Hope this helps!
Rob
Re: ip phone 7961-g
Dear
It has got only two ethernet ports 'where to connect all the six lines?
Re: ip phone 7961-g
hi,
wht do u mean by lines, as mentioned in previous post its a 6 line phone ( 6 ext) however physically can connect via one Ethernet cable to switch another can be used to connect PC.
634
