ip phone 7962 blf configure doesn´t respond
Hello
The ip phone works as assistant with blf configured. Sometime the user when press the blf it doesn´t respond and can not activate it.
The phone has two blf keys and the issue happens with both. The problem resolves after a indeterminated time without any intervention.
We have changed the set.
any idea?
Thanks Anna
I would try upgrading the
I would try upgrading the firmware version.
Please rate useful posts.
Did you found the solution? i
Did you found the solution? i have a similar case with the 7962 and 7965.
100
