Community Member
Ip phone 8831not registering
Hello engineers
I have a problem with some IP phone 8831 that are not registering because of a wrong firmware.
Could you tell me which is the right firmware for this?
I have this version:
                     CUCM 9.1.1.20000-5
Best regards!
1 ACCEPTED SOLUTION
Re: Ip phone 8831not registering
I was refering some data sheet and rls notes, This is SIP phone and you are registering as SCCP, possible reason that its not getting register.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps12965/data_sheet_c78-726887.html
also check below read me file for compatibility
http://www.cisco.com/web/software/282074299/104182/cmterm-devicepack-9_1_1_21026-1_Readme.pdf
Table 1: Cisco IP Phone Models 8831 Firmware Load
CallManager Version
Supported Protocol
Executable on Software Page
MD5 hash
8831
7.1.5, 8.5.1, 8.6.2, 9.1.1 and higher
SIP
cmterm-8831-sip.9-3-3-5.cop.sgn
2a001eafb65868e7c5c51b9301695e16
Table 2. Features and Specifications of Cisco Unified IP Conference Phone 8831
Feature
Specification
Signaling protocol support
Session Initiation Protocol (SIP)
you can try as SIP.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
are you registering phones as SCCP or SIP?
Br,
Nadeem
Community Member
Hello Nadeem
Thank you for your quick answer. Phones are registering as SCCP, I have uploaded the pack cmterm-devicepack9.1.1.21026-1.cop.sgn, but it gives me the nexte error:
Major, minor and maintenance version numbers obteined from the name do NOT match those of the current version.
any idea?
CallManager Version
Supported Protocol
MD5 hash
8831
SIP
Feature
Specification
you can try as SIP.
Br,
Nadeem
Community Member
Thank you very much!
I will try this and I will mantain you informed.
Regards!
1261
