Community Member
IP phone always update firmware from default router
  Hi all,
I am using Cisco IP Phone 7961. When I reset the IP Phone, it always updates firmware from default router first. So, start-up time is very long.
Please help me.
Thuc
Hall of Fame Super Silver
Re: IP phone always update firmware from default router
What system And version? What firmware version?
Community Member
I am using CUCM version 7.0.
Thuc
Hmm, bad rating just for asking a question on information that should have been provided in the first place
Good luck...
To whoever rated (I'm assuming it was who posted the question), you DO NOT rate when someone is asking you for further information you failed to provide to give you answer to your question, and specially on a FREE forum where people like Chris, who have a lot of experience, try to help your for FREE.
Doing that, will get you no answers to any of your questions in no time.
+5 to Chris for trying to help here.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Nguyen,
Remember the phone will download the files from the TFTP service specifiy at Option 150 (running DHCP) or the TFTP server specifiy manually on the phone.
Look like the TFTP specifify is not pointing to CUCM.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Community Member
Sorry Chris, Maybe wrong click ...
Thanks Jamie for your advice.
Thuc
Community Member
Hi Ieosalcie,
I checked in IP Phone setting. There are alternate option "Yes" and the static TFTP IP address which is a cucm server.
So, any ideas.
Thuc
Ok, so look like is pointing to the right TFTP server.
1. Go to Device->Device setting->Device Default.
2. Look for Cisco 7961 device type.
3. The firmware name should match with the one you want to upgrade the phone.
Be sure the last steps are right.
Community Member
Hi Leo,
The version is SCCP41.8-4-3S which is matched with firmware version in IP phone.
Thuc
That's weird. Did you try restarting the TFTP Service?
320
