IP phone automatic login in morning and logout in evening
Customer has CUCM 9.X and wanted to have time of the day configured in CUCM, where in user ip phone should login automatically every day in the morning and the phone should go logout automatically in evening by 6PM, user should not place calls after this time, [conditional if user wanted to place a call after 6PM there shoud be security like authentication PIN or something like,]
can anyone let me know weather it is possible, if yes please let me know the configuration on CUCM.
1 ACCEPTED SOLUTION
Hi Mohammed, Please refer the
Hi Mohammed,
Please refer the below links.
https://supportforums.cisco.com/document/54501/how-configure-time-day-routing-communications-manager
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/accm-712-cm/a03tod.html
Here you can assign the time schedule to the partition which is applied to Route partition to allow call during normal operation time.
After 6 that partition should be inactive and new partition with FAC applied on route pattern should be active.
so the user after 6 should be using the Route pattern with FAC.
This is some what raw idea, may be you need to implement and test it.
But when you say user should be automatically login and logout then EM (extension mobilty) can help.
Please provide little more clarification.
Kind Regards,
Raaj.
Hi Mohammed,
Kind Regards,
Raaj.
Dear Rajkumar, Thanks for
Dear Rajkumar,
Thanks for your the quick response, let me try this option and come back again.
If you mean login and logout
If you mean login and logout of EM, no, that's not built into CUCM.
java
if this helps, please rate
www.cisco.com/go/pdi
Dear Jaime Thanks for your
Dear Jaime
Thanks for your response and time given to write the answer, i tried the Raaj option above it worked out. EM is also something which i will be implementing in next phase.
Thanks, Again
Hi Mohammad,Did the FAC issue
Hi Mohammad,
Did the FAC issue resolved ?
I assume little misconfiguration in the FAC is the only concern here.
May be this should help here.
https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/4113-102-2-11871/Forced_Code_authorization-pdf.pdf
kind Regards,
Raaj.
Hi Raaj Yes the FAC issue
Hi Raaj
Yes the FAC issue resolved, it was it was a little misconfig as you said.
Ateeq
Guys i have an issue with
Guys i have an issue with call transfer to Mobile, if a CUG user call an internal extension and if that call gets transferred to the dialed person's mobile, the incoming call displays board line number on the mobile instead the proper DID phone number.
Route pattern is last 4 digits are XXXX
can some one have any idea how i can go about trouble shoot this.
Dear Raaj I tried this option
Dear Raaj
I tried this option in Lab scenario using CUCM 8.6 and a CIPC installed on a PC, created 2 time schedules with 2 partitions but on a dummy voicegateway called in for route pattern, works good, but FAC i feel not triggering up, after dialing the digits it only beeps there is no FAC beeps to enter the pin code.
118
