IP Phone Background Image 7945 and 9951
We have CUCM 9.1 with 7945 and 9951 phones, I have uploaded new background imanges for these phone models, and users chan change the background image by user options succesfully. But I need to push same background image to every phone, no need to give an option to user select background image, CUCM should change the background image of every phone, how can i do this ?
Regds
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Here is one such 3rd party product:
http://www.voipintegration.com/Software/Background-Deployment/
HTH,
Chris
Hall of Fame Super Gold
CUCM does not push backgrounds.
For that your need a third-party application, for which you can search.
HTH,
Chris
Thnaks Chris, it works, you need to make sure that Web Access shoul be enabled.
Hello Sir,
Hello Sir,
What is the command to enable the Web Access? Thank you
Check on the phone page. You
Check on the phone page. You should have option there to Enable Web Access
Deepak
You can also use the software called PhoneView. Its a third party software and it pushes out the images. The only downfall to it is that if the user goes in to change the image, you cannot not retrieve the pushed image if its not already loaded to the TFTP.
964
