IP Phone Call History
Hello everyone,
I've got a UC500 installation with two 7941 IP Phones and for some reason, there is no call history on the IP Phones. As such, the customer is unable to view his missed calls!
Any idea what the problem might be ? I've also connected an IP Communicator to see if the problem is related to the IP Phone software but the same problem occurs.
Any ideas or suggestions are much appreciated.
Thanks !
Green
Re: IP Phone Call History
Which Firmware,?
that happens for IP Phone to IP phone as weel??
running SCCP?
Can you see called number? Only missed calls?
Gogasca,
Many thanks for your interest.
All IP Phones are running sccp and the UC520 is using the following firmware:
(UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW6
I've now upgraded it to uc500-advipservicesk9-mz.124-11.XW9 and awaiting the customer so I can reboot the UC and see if we have different results.
To provide more details, when there's an incoming call, the number of the calling party is shown on the IP Phone, but not listed in the call history (missed or answered calls).
One small additional detail which might be important. The 7941 phones installed came from a different installation site where they were running CCME 4.0.1 if I remember correctly and thus their firmware might have been upgraded back then;
I've also got one of these 7941 phones in my lab, running on a 1760 with CCME 4.0 and I'm experiencing the same problem!
Do you beleive it might be an issue with the firmware loaded on the phones ?
Cheers,
I have run into this issue before, and it was a firmware problem. I had to do create-cnf files to make the config files look the newest for the CME, and then get the UC520 to load them with the firmware it wanted to have on them, and the problem was resolved. Hopefully this will assist it your situation as well.
Steve
slongewa
Yes, that's what I thought it might be as it doesn't seem logical to be associated with the IOS - its basic functionality so it should work 'out of the box' !
I'll give it a try and update this thread for future reference for this community.
Cheers mate,
I've just done some testing on my 1760 CCME 4.0.2 system.
After downloading the 7941G firmware associated with my IOS reload (12.4.11T) I reset the phone and let it update its firmware. Tested the missed call functionality and still the same problem.
However, I did notice that when I hit the 'Directories' button, I received a "Host Not Found" message on the lower section of the screen.
Following is my 'telephony service' configuration in case it helps:
telephony-service
load 7941 SCCP41.8-0-4SR2S
max-ephones 30
max-dn 150
ip source-address 192.168.0.5 port 2000
system message Cisco Call Manager Express
network-locale GB
time-zone 31
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
moh music-on-hold.au
multicast moh 239.10.16.4 port 2000
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
Thanks.
Update.
I've been continuing my tests with the 1760 in my lab and discovered that the problem is related to the 'overlay' feature used to combine multiple lines to one physical button!!
While this might sound abnormal, I've tested it out and everytime I configured the phone to one single line ( button 1:x), I was able to see the missed calls under the directory/missed calls section.
When changing the phone's config to button 1o1,20 , and cleared the call history, all future calls wouldn't show up in the 'missed calls' section!!
Has anyone seen this 'bug' or am I missing something here ???
I'll try the same scenario at my customer tommorow and I've got a feeling the same problem will occur there.
Any ideas ?
592
