Ip Phone dead?
Hi experts,
We just upgraded the firmware of our 7941s. All are good except one. It doesn't upgrade at all. I factory reset it by holding #, 123456789*0#.
After this, it's still not fixed. Then I directly connected it to a laptop as TFTP server with SEPxxxxxx.cnf, term41.defaults.loads, etc. with it.
However the phone is not responding at all. Then I factory reset it again the 2nd time. Now the speaker button & line button blink once, then it's dead. no power.
I also tried connecting a power supply but the same happens. the speaker button & line button blink once, then it's dead.
Can anyone help me how to troubleshoot it? Or the only thing I should do is forward it to TAC?
tnx
Hall of Fame Super Gold
Re: Ip Phone dead?
Try the alternate reset sequence:
3491672580*#
After that, wait, it can take 10 minutes without display activity to revive the phone.
Re: Ip Phone dead?
Is it the same sequence (factory reset)for 7912? I have few phones that dont reboot after upgrading firmware to 8.04.
Re: Ip Phone dead?
thanks p.bevilacqua
Tried it but no success!
any more idea?
tnx
Re: Ip Phone dead?
Do packet capture and you will see that either the phone is not give a valid dhcp reply with option 150, or it reuest some file that the tftp server doesn't give.
Re: Ip Phone dead?
Hi Can anyone give me what should be on the SEP.CNF.XML & xmlDefault.CNF.XML. Seems i'm lacking something on it.
thanks
Re: Ip Phone dead?
What do you have, CM or CME ? check that the ephone is configured correctly in there.
Re: Ip Phone dead?
CM with 7941G sccp phone.
firmware:SCCP41.8-3-4SR1S
tnx
Re: Ip Phone dead?
Finally I was able to fixed it.
tnx
Re: Ip Phone dead?
How about description of how the problem was solved, then at least these postings are usefull.
Re: Ip Phone dead?
Hello, I'm facing the same problem. Could you please share with me what was done to fix the issue? Thank you.
Re: Ip Phone dead?
The only thing that I've done is set a specific pc as a TFTP server, then I copied all the phone's files from my CM for that particular model. Then when all was set, i reset it as advised then it works!
hth
522
