Community Member
IP phone deployment: stuck in "Configuring IP" mode
Currently, we are deploying about 40 IP phones for our company(We already had about 100 ip phones). When we deploy these IP phones, some of them (1/5) stuck in the "Configuring IP" mode while others boot up successfully.
Phone model: 7970G
firmware version:
SCCP70.8-3-3SR2S (success)
SCCP70.8-3-3 (stuck)
Re: IP phone deployment: stuck in "Configuring IP" mode
if you try to configure the phones manually does it work??
usually configuring IP is not related to firmware but to a DHCP issue. do the switch ports have a valid DHCP scope or free ip addresses??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
When I encounted with this issue, I tried to replace another phone set to the same switch port, and it can boot up.
So I wonder it might not the switch or network problem.
Hello Jeff,
Have you ran any debug ip dhcp commands?
This initially sounds like a DHCP or firmware issue.
Justin
Community Member
Can you teach me how to configure the phone "manually"?
for example, how to configure DHCP for a phone?
Community Member
I wonder if its a licensing thing, have you checked your licenses since you started adding new phones?
Community Member
I am experiencing the same problem but with different firmware.
Phone 7961
Firmware sccp41.8-3-4sr1s. The phone gets stuck in configuring up after upgrading firmware from sccp41.8-3-2sr1s.
I had to move the phone to a different port and go back to the lower revision. Trying to find out why this is happening
Community Member
I've had this with a UC520 system as well as a 2800, with different handsets and differing software models.
Believe it or not my issue was dodgy wall sockets and badly made network cables.
After re-terminating the wall sockets and renewing the cables my issue dissapeared.
It looks like some of the sockets were providing power, but not providing adequate network capabilities.
Community Member
My problem is while using the same switch port, same connection cable, some phone can boot up, but others are stuck in...
795
