IP Phone doesn't ring
Hello everyone,
I have another strange issue with an IP phone that doesn't want to ring.
There are 4 analog lines plugged into an FXO card in the router, and all are configured the same. The lines are PLARed to the phones - and all but one are working.
I've run a debug vpm signal and received the following output.
htsp_process_event: [0/1/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
htsp_timer - 125 msec
htsp_process_event: [0/1/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
htsp_timer - 10000 msec
htsp_timer3 - 5600 msec
[0/1/3] htsp_start_caller_id_rx:BELLCORE
[0/1/3] htsp_dsm_create_success returns 1
htsp_process_event: [0/1/3, FXOLS_RINGING, E_DSP_SIG_0000]
[0/1/3] htsp_dsm_feature_notify_cb returns 2 id=DSM_FEATURE_SM_CALLERID_RX
htsp_process_event: [0/1/3, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
fxols_callerid_done: no ring detected
htsp_process_event: [0/1/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
htsp_timer_stop3
htsp_process_event: [0/1/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER]fxols_ringing_disc
htsp_timer_stop3
htsp_timer_stop
[0/1/3] htsp_stop_caller_id_rx. message length 42
[0/1/3] htsp_dsm_close_done
htsp_timer_stop3
htsp_timer_stop3
htsp_timer_stop
[0/1/3] htsp_stop_caller_id_rx. message length 0
Mar 12 03:31:14.483: htsp_process_event: [0/1/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
htsp_timer_stop3
htsp_timer_stop3
htsp_timer_stop
I notice the 'no ring detected' in the output, and I'm wondering what the problem could be.
The show voice call summary output shows the VPM STATE as FXOLS_RINGING, but the phone itself doesn't ring.
Is there anything someone sees that I'm missing?
Any help would be appreciated!
Ali
Re: IP Phone doesn't ring
Is this Callmanager or CME ?
It's CME - very small office with a couple phones.
When you make internal calls between phones does the phone ring ?
Try a csim start from the router, does the phone ring ?
PLAR all 4 FXO lines to the ip phone in question and call each FXO number from PSTN, see if all 4 fail or one but all fails...
Many thanks to your replies...
I've done what you suggested.
Internal calls don't have any problems, they can call to eachother through extensions.
I performed a csim start and it went through successfully, meaning that it gave me no errors. I tried a couple invalid numbers and it gave me errors but when I typed the extension it went through.
I PLARed another line to the extension, and called the number, and it went through! Well, ofcourse I had to PLAR it back to the original line...
So does that indicate anything? I'm thinking of the FXO port being faulty but the phone doesn't have any problems making calls outbound. It just doesn't ring when someone dials that number from outside...
Thanks again!!
Ali
Ok - I got the problem fixed.
The problem was with the FXO card itself. I think the DSP on the board was probably defected.
We ordered a new card, plugged it in, and bam... started working again.
Thanks again for the replies and help.
Ali
1385
